Ir para o conteúdo principal
HP Mini 210 CMOS Battery Replacement
O que você precisa
  1. HP Mini 210 CMOS Battery Replacement, Battery: passo 1, imagem 1 %32 HP Mini 210 CMOS Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    Pergunte ao FixBot
    Comentar
  2. HP Mini 210 CMOS Battery Replacement: passo 2, imagem 1 %32
    • Slide the battery out from the netbook.
    Pergunte ao FixBot
    Comentar
  3. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: passo 3, imagem 1 %32
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    Pergunte ao FixBot
    Comentar
  4. HP Mini 210 CMOS Battery Replacement: passo 4, imagem 1 %32
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    Pergunte ao FixBot
    Comentar
  5. HP Mini 210 CMOS Battery Replacement: passo 5, imagem 1 %32
    • Pull the back case off from the front edge.
    Pergunte ao FixBot
    Comentar
  6. HP Mini 210 CMOS Battery Replacement, CMOS Battery: passo 6, imagem 1 %32
    • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
    • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
    Pergunte ao FixBot
    Comentar
  7. HP Mini 210 CMOS Battery Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Slowly peel back the black adhesive ribbon with tweezers.
    Pergunte ao FixBot
    Comentar
  8. HP Mini 210 CMOS Battery Replacement: passo 8, imagem 1 %32
    • Pry the CMOS battery out with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  9. HP Mini 210 CMOS Battery Replacement: passo 9, imagem 1 %32
    • Pop the CMOS battery out.
    • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Heather Freed
Membro desde: 10/06/12
723 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 9-17, Amido Fall 2012 Membro de Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Membros
Autoria de 8 guias
2Comentários do guia
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - Responder Compartilhar
Very good tut. Now my HP Mini 210 can get the right time xD
Byte Core - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 79
Ao todo: 17,101
