Ir para o conteúdo principal
HP Mini 110-3735dx Keyboard Replacement
O que você precisa
  1. HP Mini 110-3735dx Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement, Battery: passo 1, imagem 2 %32 HP Mini 110-3735dx Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
    Pergunte ao FixBot
    Comentar
  2. HP Mini 110-3735dx Keyboard Replacement: passo 2, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement: passo 2, imagem 2 %32
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
    Pergunte ao FixBot
    Comentar
  3. HP Mini 110-3735dx Keyboard Replacement, Backcover: passo 3, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement, Backcover: passo 3, imagem 2 %32 HP Mini 110-3735dx Keyboard Replacement, Backcover: passo 3, imagem 3 %32
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
    Pergunte ao FixBot
    Comentar
  4. HP Mini 110-3735dx Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
    Pergunte ao FixBot
    Comentar
  5. HP Mini 110-3735dx Keyboard Replacement: passo 5, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement: passo 5, imagem 2 %32
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
    Pergunte ao FixBot
    Comentar
  6. HP Mini 110-3735dx Keyboard Replacement: passo 6, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement: passo 6, imagem 2 %32
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
    Pergunte ao FixBot
    Comentar
  7. HP Mini 110-3735dx Keyboard Replacement: passo 7, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement: passo 7, imagem 2 %32
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
    Pergunte ao FixBot
    Comentar
  8. HP Mini 110-3735dx Keyboard Replacement: passo 8, imagem 1 %32
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
    Pergunte ao FixBot
    Comentar
  9. HP Mini 110-3735dx Keyboard Replacement: passo 9, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement: passo 9, imagem 2 %32
    • Lift the black holder connected to the keyboard cable until it points up.
    Pergunte ao FixBot
    Comentar
  10. HP Mini 110-3735dx Keyboard Replacement: passo 10, imagem 1 %32 HP Mini 110-3735dx Keyboard Replacement: passo 10, imagem 2 %32
    • Gently pull the keyboard cable from the socket.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 26
Ao todo: 1,080
