Ir para o conteúdo principal
HP Mini 110-3735dx Hard Drive Replacement
O que você precisa
    1. HP Mini 110-3735dx Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement, Battery: passo 1, imagem 3 %32
      • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 110-3735dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 2, imagem 2 %32
      • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 110-3735dx Hard Drive Replacement, Backcover: passo 3, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement, Backcover: passo 3, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement, Backcover: passo 3, imagem 3 %32
      • Pull upward from under the back cover via the missing battery area.
      • Best to start from one of the corners.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive Cage: passo 4, imagem 1 %32
      • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 110-3735dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 5, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 5, imagem 3 %32
      • Lift the hard drive cage by pulling the tape upward.
      • Start by pulling the tape from the side with the keyboard symbol.
      Pergunte ao FixBot
      Comentar
    3. HP Mini 110-3735dx Hard Drive Replacement: passo 6, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 6, imagem 2 %32
      • Unplug the cable connecting to the hard drive.
      Pergunte ao FixBot
      Comentar
    1. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: passo 7, imagem 3 %32
      • Remove the four 4.0 mm screws on both sides of the cage using a Phillips #1 screw driver.
      Pergunte ao FixBot
      Comentar
    2. HP Mini 110-3735dx Hard Drive Replacement: passo 8, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 8, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 8, imagem 3 %32
      • Gently remove the hard drive from it's cage.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 970
