Ir para o conteúdo principal
HP Mini 1000 RAM Replacement
O que você precisa
  1. HP Mini 1000 RAM Replacement, Battery: passo 1, imagem 1 %32 HP Mini 1000 RAM Replacement, Battery: passo 1, imagem 2 %32
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
    Pergunte ao FixBot
    Comentar
  2. HP Mini 1000 RAM Replacement: passo 2, imagem 1 %32
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
    Pergunte ao FixBot
    Comentar
  3. HP Mini 1000 RAM Replacement, RAM: passo 3, imagem 1 %32 HP Mini 1000 RAM Replacement, RAM: passo 3, imagem 2 %32
    • Before proceeding, slide the right battery release latch to the unlocked position nearest the center of the computer.
    • Use the tip of a spudger to slide the RAM compartment cover release latch away from the center of the computer.
    • At this point, the edge of the RAM compartment cover nearest the battery compartment should pop up from the lower case.
    Pergunte ao FixBot
    Comentar
  4. HP Mini 1000 RAM Replacement: passo 4, imagem 1 %32
    • Remove the RAM compartment cover from the lower case.
    Pergunte ao FixBot
    Comentar
  5. HP Mini 1000 RAM Replacement: passo 5, imagem 1 %32 HP Mini 1000 RAM Replacement: passo 5, imagem 2 %32
    • Use your fingers to simultaneously pull both RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should pop up slightly from its socket.
    • Pull the RAM chip out of its socket and remove it from the Mini 1000.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 49
Ao todo: 4,944
