Ir para o conteúdo principal
HP G71t-300 Keyboard Replacement
O que você precisa
    1. HP G71t-300 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 HP G71t-300 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 HP G71t-300 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
      Ferramenta utilizada neste passo:
      Anti-Static Wrist Strap
      $7.95
      • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
      • Turn off the computer and remove the charger from the charging port.
      • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
      Pergunte ao FixBot
      Comentar
    2. HP G71t-300 Keyboard Replacement: passo 2, imagem 1 %32 HP G71t-300 Keyboard Replacement: passo 2, imagem 2 %32
      • Use a Phillips #0 screwdriver to remove the four screws from the indicated cover.
      • Gently lift and remove the cover.
      Pergunte ao FixBot
      Comentar
    3. HP G71t-300 Keyboard Replacement: passo 3, imagem 1 %32 HP G71t-300 Keyboard Replacement: passo 3, imagem 2 %32
      • Remove the five 6mm screws with the Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. HP G71t-300 Keyboard Replacement: passo 4, imagem 1 %32 HP G71t-300 Keyboard Replacement: passo 4, imagem 2 %32
      • Pry the keyboard off with a spudger. Be careful not to apply too much pressure and damage any components.
      Pergunte ao FixBot
      Comentar
    5. HP G71t-300 Keyboard Replacement: passo 5, imagem 1 %32 HP G71t-300 Keyboard Replacement: passo 5, imagem 2 %32
      • Disconnect the clip attaching the keyboard wiring to the motherboard. Lift and remove the keyboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Rohan Mathew
Membro desde: 09/22/16
513 Reputação
Autoria de 5 guias
Equipe
UC Davis, Team 2-3, Oliver Fall 2016 Membro de UC Davis, Team 2-3, Oliver Fall 2016
UCD-OLIVER-F16S2G3
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 458
