Ir para o conteúdo principal
HP G62-234DX Keyboard Replacement
O que você precisa
  1. HP G62-234DX Keyboard Replacement, Wi-Fi Card: passo 1, imagem 1 %32 HP G62-234DX Keyboard Replacement, Wi-Fi Card: passo 1, imagem 2 %32 HP G62-234DX Keyboard Replacement, Wi-Fi Card: passo 1, imagem 3 %32
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  2. HP G62-234DX Keyboard Replacement: passo 2, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 2, imagem 2 %32 HP G62-234DX Keyboard Replacement: passo 2, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
    • The screws that are attached to the panel do not need to be removed completely.
    • Remove the back panel to access the Wi-Fi card.
    Pergunte ao FixBot
    Comentar
  3. HP G62-234DX Keyboard Replacement: passo 3, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 3, imagem 2 %32 HP G62-234DX Keyboard Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    Pergunte ao FixBot
    Comentar
  4. HP G62-234DX Keyboard Replacement: passo 4, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
    • When the screw is removed the card will pop up at a 45-degree angle.
    Pergunte ao FixBot
    Comentar
  5. HP G62-234DX Keyboard Replacement: passo 5, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 5, imagem 2 %32 HP G62-234DX Keyboard Replacement: passo 5, imagem 3 %32
    • Remove the Wi-Fi card by sliding it out from the socket.
    Pergunte ao FixBot
    Comentar
  6. HP G62-234DX Keyboard Replacement, Keyboard: passo 6, imagem 1 %32 HP G62-234DX Keyboard Replacement, Keyboard: passo 6, imagem 2 %32 HP G62-234DX Keyboard Replacement, Keyboard: passo 6, imagem 3 %32
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM chip.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Slide the RAM card out of the slot to remove it.
    Pergunte ao FixBot
    Comentar
  7. HP G62-234DX Keyboard Replacement: passo 7, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 7, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove three 6.5 mm screws.
    • Use a Phillips #0 screwdriver to remove three 5.0 mm screws.
    Pergunte ao FixBot
    Comentar
  8. HP G62-234DX Keyboard Replacement: passo 8, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 8, imagem 2 %32
    • Rotate the laptop back to its standard orientation and flip open the screen.
    • Use the iFixit opening tool to separate the keyboard from the tabs. Start from one point on the edge and work your way around until all of the tabs are released.
    Pergunte ao FixBot
    Comentar
  9. HP G62-234DX Keyboard Replacement: passo 9, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 9, imagem 2 %32 HP G62-234DX Keyboard Replacement: passo 9, imagem 3 %32
    • Flip the keyboard towards yourself.
    • Do not try to pull it out, as it is still connected to the ribbon cable.
    Pergunte ao FixBot
    Comentar
  10. HP G62-234DX Keyboard Replacement: passo 10, imagem 1 %32 HP G62-234DX Keyboard Replacement: passo 10, imagem 2 %32
    • Flip up the locking flap using either your fingernail, or a spudger.
    • Remove the ribbon from the ZIF connector.
    Pergunte ao FixBot
    Comentar
  11. HP G62-234DX Keyboard Replacement: passo 11, imagem 1 %32
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order with the replacement keyboard. Make sure to be careful when reconnecting small or delicate pieces, and don't rush!
Kate Ferland
Membro desde: 11/01/23
836 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 39
Ao todo: 664
