Ir para o conteúdo principal
HP G62-234DX Fan Replacement
O que você precisa
  1. HP G62-234DX Fan Replacement, Wi-Fi Card: passo 1, imagem 1 %32 HP G62-234DX Fan Replacement, Wi-Fi Card: passo 1, imagem 2 %32 HP G62-234DX Fan Replacement, Wi-Fi Card: passo 1, imagem 3 %32
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  2. HP G62-234DX Fan Replacement: passo 2, imagem 1 %32 HP G62-234DX Fan Replacement: passo 2, imagem 2 %32 HP G62-234DX Fan Replacement: passo 2, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
    • The screws that are attached to the panel do not need to be removed completely.
    • Remove the back panel to access the Wi-Fi card.
    Pergunte ao FixBot
    Comentar
  3. HP G62-234DX Fan Replacement: passo 3, imagem 1 %32 HP G62-234DX Fan Replacement: passo 3, imagem 2 %32 HP G62-234DX Fan Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    Pergunte ao FixBot
    Comentar
  4. HP G62-234DX Fan Replacement: passo 4, imagem 1 %32 HP G62-234DX Fan Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
    • When the screw is removed the card will pop up at a 45-degree angle.
    Pergunte ao FixBot
    Comentar
  5. HP G62-234DX Fan Replacement: passo 5, imagem 1 %32 HP G62-234DX Fan Replacement: passo 5, imagem 2 %32 HP G62-234DX Fan Replacement: passo 5, imagem 3 %32
    • Remove the Wi-Fi card by sliding it out from the socket.
    Pergunte ao FixBot
    Comentar
  6. HP G62-234DX Fan Replacement, Keyboard: passo 6, imagem 1 %32 HP G62-234DX Fan Replacement, Keyboard: passo 6, imagem 2 %32 HP G62-234DX Fan Replacement, Keyboard: passo 6, imagem 3 %32
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM chip.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Slide the RAM card out of the slot to remove it.
    Pergunte ao FixBot
    Comentar
  7. HP G62-234DX Fan Replacement: passo 7, imagem 1 %32 HP G62-234DX Fan Replacement: passo 7, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove three 6.5 mm screws.
    • Use a Phillips #0 screwdriver to remove three 5.0 mm screws.
    Pergunte ao FixBot
    Comentar
  8. HP G62-234DX Fan Replacement: passo 8, imagem 1 %32 HP G62-234DX Fan Replacement: passo 8, imagem 2 %32
    • Rotate the laptop back to its standard orientation and flip open the screen.
    • Use the iFixit opening tool to separate the keyboard from the tabs. Start from one point on the edge and work your way around until all of the tabs are released.
    Pergunte ao FixBot
    Comentar
  9. HP G62-234DX Fan Replacement: passo 9, imagem 1 %32 HP G62-234DX Fan Replacement: passo 9, imagem 2 %32 HP G62-234DX Fan Replacement: passo 9, imagem 3 %32
    • Flip the keyboard towards yourself.
    • Do not try to pull it out, as it is still connected to the ribbon cable.
    Pergunte ao FixBot
    Comentar
  10. HP G62-234DX Fan Replacement: passo 10, imagem 1 %32 HP G62-234DX Fan Replacement: passo 10, imagem 2 %32
    • Flip up the locking flap using either your fingernail, or a spudger.
    • Remove the ribbon from the ZIF connector.
    Pergunte ao FixBot
    Comentar
  11. HP G62-234DX Fan Replacement: passo 11, imagem 1 %32
    • Remove the keyboard.
    Pergunte ao FixBot
    Comentar
  12. HP G62-234DX Fan Replacement, Fan: passo 12, imagem 1 %32 HP G62-234DX Fan Replacement, Fan: passo 12, imagem 2 %32
    • Close the laptop and flip it back over.
    • Use a Phillips #0 screwdriver to loosen two screws securing the panel.
    • The screws are attached to the panel and do not need to be removed completely.
    • Remove the HDD panel.
    Pergunte ao FixBot
    Comentar
  13. HP G62-234DX Fan Replacement: passo 13, imagem 1 %32 HP G62-234DX Fan Replacement: passo 13, imagem 2 %32 HP G62-234DX Fan Replacement: passo 13, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove two 6.0 mm screws.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Pull the cables out from the connectors attached to the touchpad and fan.
    Pergunte ao FixBot
    Comentar
  14. HP G62-234DX Fan Replacement: passo 14, imagem 1 %32 HP G62-234DX Fan Replacement: passo 14, imagem 2 %32 HP G62-234DX Fan Replacement: passo 14, imagem 3 %32
    • Use a spudger and opening picks to pry the palm rest assembly from the laptop.
    Pergunte ao FixBot
    Comentar
  15. HP G62-234DX Fan Replacement: passo 15, imagem 1 %32 HP G62-234DX Fan Replacement: passo 15, imagem 2 %32 HP G62-234DX Fan Replacement: passo 15, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  16. HP G62-234DX Fan Replacement: passo 16, imagem 1 %32 HP G62-234DX Fan Replacement: passo 16, imagem 2 %32 HP G62-234DX Fan Replacement: passo 16, imagem 3 %32
    • Use a Phillips #0 screwdriver to loosen the captive screw securing the fan.
    • Lift the motherboard slowly from the right side and take off gently.
    • Do not pull too hard if you encounter a lot of resistance; double-check if you forgot to remove any screws.
    Pergunte ao FixBot
    Comentar
  17. HP G62-234DX Fan Replacement: passo 17, imagem 1 %32 HP G62-234DX Fan Replacement: passo 17, imagem 2 %32
    • Flip the motherboard over.
    Pergunte ao FixBot
    Comentar
  18. HP G62-234DX Fan Replacement: passo 18, imagem 1 %32 HP G62-234DX Fan Replacement: passo 18, imagem 2 %32 HP G62-234DX Fan Replacement: passo 18, imagem 3 %32
    • Use a Phillips #0 screwdriver to loosen the screws on the CPU block.
    • Disconnect the power cable right next to the fan.
    • Gently remove the fan assembly.
    Pergunte ao FixBot
    Comentar
  19. HP G62-234DX Fan Replacement: passo 19, imagem 1 %32 HP G62-234DX Fan Replacement: passo 19, imagem 2 %32 HP G62-234DX Fan Replacement: passo 19, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the screws from the fan.
    Pergunte ao FixBot
    Comentar
  20. HP G62-234DX Fan Replacement: passo 20, imagem 1 %32 HP G62-234DX Fan Replacement: passo 20, imagem 2 %32 HP G62-234DX Fan Replacement: passo 20, imagem 3 %32
    • Gently take off the blades.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Don't forget to reattach the cables and check for screws at every step of the reassembly process!
Uma outra pessoa concluiu este guia.
Kate Ferland
Membro desde: 11/01/23
836 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 619
