Ir para o conteúdo principal
HP G62-223CL RAM Replacement
O que você precisa
  1. HP G62-223CL RAM Replacement, Battery Removal: passo 1, imagem 1 %32 HP G62-223CL RAM Replacement, Battery Removal: passo 1, imagem 2 %32
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
    Pergunte ao FixBot
    Comentar
  2. HP G62-223CL RAM Replacement: passo 2, imagem 1 %32
    • Carefully remove the battery from its compartment.
    Pergunte ao FixBot
    Comentar
  3. HP G62-223CL RAM Replacement, RAM: passo 3, imagem 1 %32
    • Locate three Phillips head retaining screws which secure RAM compartment.
    • Use a Phillips #0 screwdriver to loosen the screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    Pergunte ao FixBot
    Comentar
  4. HP G62-223CL RAM Replacement: passo 4, imagem 1 %32 HP G62-223CL RAM Replacement: passo 4, imagem 2 %32
    • Use the tip of a screw driver to press the release clips away from the RAM module.
    • Once the second clip is released, the module will automatically pop up.
    Pergunte ao FixBot
    Comentar
  5. HP G62-223CL RAM Replacement: passo 5, imagem 1 %32
    • Carefully remove module from slot.
    • Be careful not to damage modules when removing them from their slots.
    Pergunte ao FixBot
    Comentar
  6. HP G62-223CL RAM Replacement: passo 6, imagem 1 %32 HP G62-223CL RAM Replacement: passo 6, imagem 2 %32
    • Repeat steps 4 and 5 for additional RAM modules.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Garret Layton
Membro desde: 01/13/15
687 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-4, Sullivan Winter 2015 Membro de USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 943
