Ir para o conteúdo principal
HP G60 RAM Replacement
O que você precisa
    1. HP G60 RAM Replacement, Battery: passo 1, imagem 1 %32 HP G60 RAM Replacement, Battery: passo 1, imagem 2 %32 HP G60 RAM Replacement, Battery: passo 1, imagem 3 %32
      • First, you should to remove the battery to avoid electric shocks
      • Slide and unlock the battery, then, lift it
      Pergunte ao FixBot
      Comentar
    2. HP G60 RAM Replacement, RAM cover: passo 2, imagem 1 %32 HP G60 RAM Replacement, RAM cover: passo 2, imagem 2 %32 HP G60 RAM Replacement, RAM cover: passo 2, imagem 3 %32
      • Remove the two screws with a not too large screwdriver
      • Now lift the cover, the screws are part of the cover
      Pergunte ao FixBot
      Comentar
    3. HP G60 RAM Replacement, Eject RAM: passo 3, imagem 1 %32 HP G60 RAM Replacement, Eject RAM: passo 3, imagem 2 %32 HP G60 RAM Replacement, Eject RAM: passo 3, imagem 3 %32
      • Push the little aluminum locks at the top and the bottom of the ram
      • The memory will lift, then pull it
      • Make this with the another RAM slot
      Pergunte ao FixBot
      Comentar
    4. HP G60 RAM Replacement, New RAM: passo 4, imagem 1 %32 HP G60 RAM Replacement, New RAM: passo 4, imagem 2 %32 HP G60 RAM Replacement, New RAM: passo 4, imagem 3 %32
      • The new RAM memory should to be insert in a 45 degrees angle
      • Then, push it and the memory will lock by itself
      • Make this with the second memory
      Pergunte ao FixBot
      Comentar
    5. HP G60 RAM Replacement, RAM cover (Again): passo 5, imagem 1 %32 HP G60 RAM Replacement, RAM cover (Again): passo 5, imagem 2 %32 HP G60 RAM Replacement, RAM cover (Again): passo 5, imagem 3 %32
      • Insert the cover from right to left, then, screw it
      • If cover is lifted, press it softly and secure it
      Pergunte ao FixBot
      Comentar
Linha de Chegada
5 outras pessoas executaram este guia.
jimenezser
Membro desde: 08/29/12
3.905 Reputação
Autoria de 4 guias
1Comentário do guia
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 44
Ao todo: 6,870
