Ir para o conteúdo principal
HP Flyer Red Battery Replacement
    1. HP Flyer Red Battery Replacement, Battery: passo 1, imagem 1 %32 HP Flyer Red Battery Replacement, Battery: passo 1, imagem 2 %32
      • Make sure your laptop is powered off.
      • With laptop closed flip to look at the underside of the laptop.
      Pergunte ao FixBot
      Comentar
    2. HP Flyer Red Battery Replacement: passo 2, imagem 1 %32
      • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
      Pergunte ao FixBot
      Comentar
    3. HP Flyer Red Battery Replacement: passo 3, imagem 1 %32 HP Flyer Red Battery Replacement: passo 3, imagem 2 %32
      • The left switch is the battery unlock switch.
      • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
      Pergunte ao FixBot
      Comentar
    4. HP Flyer Red Battery Replacement: passo 4, imagem 1 %32
      • Then take and slide the other switch to the other end of its track which will pop out the battery.
      • Grab the battery and pull it out of the slot.
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
1Comentário do guia
What do you do when the battery not charging but the laptop is working when directly plugged on power
liberty siegmann derera - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 2,757
