Ir para o conteúdo principal
HP Envy x360 m6-w103dx Fan Replacement
O que você precisa
  1. HP Envy x360 m6-w103dx Fan Replacement, Keyboard: passo 1, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement, Keyboard: passo 1, imagem 2 %32
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Fan Replacement: passo 2, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 2, imagem 2 %32
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Fan Replacement: passo 3, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 3, imagem 2 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 3, imagem 3 %32
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Fan Replacement: passo 4, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 4, imagem 2 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 4, imagem 3 %32
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Fan Replacement, Motherboard: passo 5, imagem 1 %32
    • Disconnect the pin head battery connection to remove power from the motherboard.
    • Unscrew the five 4mm screws holding the motherboard in place using a #0 Phillips screwdriver.
    • It's possible the positions of the screws will be different on your board. If the motherboard resists lifting, double-check that all screws have been removed.
  6. HP Envy x360 m6-w103dx Fan Replacement: passo 6, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 6, imagem 2 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 6, imagem 3 %32
    • Remove the five flat ribbon cables by gently lifting the head of the cable up and back.
    • Remove the two remaining multicolored ribbon cables by pulling the white plastic head backwards.
    • Do not pull directly on the wires.
    • If the head of the multicolored ribbon cable doesn't come out, try gently wiggling it side to side as you pull.
  7. HP Envy x360 m6-w103dx Fan Replacement: passo 7, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 7, imagem 2 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 7, imagem 3 %32
    • Lift the motherboard up from the left side at a shallow angle.
    • Gently pull the motherboard to the left and gently wiggle it side to side until the ports on the right side of the board detach from the case.
    • Ensure the laptop is well supported, as the motherboard is a heavy component and removing it may make the laptop off-balance.
  8. HP Envy x360 m6-w103dx Fan Replacement, Fan: passo 8, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement, Fan: passo 8, imagem 2 %32
    • Carefully lay the motherboard on a flat surface with the metal plate facing up.
    • Unscrew the four 6.0 mm screws from the heatsink using a #00 Phillips screwdriver.
    • The screws do not detach from the component, just the motherboard.
  9. HP Envy x360 m6-w103dx Fan Replacement: passo 9, imagem 1 %32
    • Disconnect the fan pin-head connector.
  10. HP Envy x360 m6-w103dx Fan Replacement: passo 10, imagem 1 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 10, imagem 2 %32 HP Envy x360 m6-w103dx Fan Replacement: passo 10, imagem 3 %32
    • Carefully lift the fan assembly and pull away from the motherboard.
    • When reassembling, be sure to clean the old thermal paste from the heatsink and CPU contact points. Then, reapply new thermal paste with our How to Apply Thermal Paste guide.
Conclusão
Uma outra pessoa concluiu este guia.
Steven Ngo
Membro desde: 10/10/19
927 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S12-G2, Regan Fall 2019 Membro de Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
Membros da 4
Autoria de 23 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 557
