Ir para o conteúdo principal
HP Envy TouchSmart 15 Wireless Adapter Replacement
O que você precisa
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: passo 1, imagem 1 %32
    • Press the battery release tab and the battery will pop up.
    Pergunte ao FixBot
    Comentar
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 2, imagem 1 %32
    • Remove the battery from the laptop, it will come out easily.
    Pergunte ao FixBot
    Comentar
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: passo 3, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: passo 3, imagem 2 %32
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
    Pergunte ao FixBot
    Comentar
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, imagem 2 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 4, imagem 3 %32
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
    Pergunte ao FixBot
    Comentar
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: passo 5, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: passo 5, imagem 2 %32
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
    Pergunte ao FixBot
    Comentar
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, imagem 1 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, imagem 2 %32 HP Envy TouchSmart 15 Wireless Adapter Replacement: passo 6, imagem 3 %32
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 2-6, Sullivan Fall 2015 Membro de USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Membros
Autoria de 10 guias
1Comentário do guia
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 3,641
