Ir para o conteúdo principal
HP Envy 7640 Printhead Replacement
O que você precisa
  1. HP Envy 7640 Printhead Replacement, Paper Roller: passo 1, imagem 1 %32 HP Envy 7640 Printhead Replacement, Paper Roller: passo 1, imagem 2 %32 HP Envy 7640 Printhead Replacement, Paper Roller: passo 1, imagem 3 %32
    • Open the printer by pushing upwards on the plastic tabs located on the sides of the printer.
    • Remove the opening assist from its purchase by pushing it toward the front of the printer with a nylon spudger.
    • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
    Pergunte ao FixBot
    Comentar
  2. HP Envy 7640 Printhead Replacement: passo 2, imagem 1 %32 HP Envy 7640 Printhead Replacement: passo 2, imagem 2 %32
    • Remove the last ten 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise.
    • Remove the last two 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise; the screen plate can now be separated from the printer by pushing out and to the right.
    • Take out the inner plastic frame (this piece is removeable after having removed the ten 12 mm screws outlined in the first bullet) by grasping the frame with both hands and carefully pulling the frame away from the printer body.
    Pergunte ao FixBot
    Comentar
  3. HP Envy 7640 Printhead Replacement: passo 3, imagem 1 %32 HP Envy 7640 Printhead Replacement: passo 3, imagem 2 %32
    • Grasp the gray lever of the black plastic cover of the rollers and gently pull the lever up and to the right.
    Pergunte ao FixBot
    Comentar
  4. HP Envy 7640 Printhead Replacement: passo 4, imagem 1 %32 HP Envy 7640 Printhead Replacement: passo 4, imagem 2 %32 HP Envy 7640 Printhead Replacement: passo 4, imagem 3 %32
    • Press the lever outwards and away from the paper rollers with one hand.
    • Pull the paper rollers up and out of your HP printer with one hand while the other continues to depress the lever away from the paper rollers.
    Pergunte ao FixBot
    Comentar
  5. HP Envy 7640 Printhead Replacement, Motherboard: passo 5, imagem 1 %32 HP Envy 7640 Printhead Replacement, Motherboard: passo 5, imagem 2 %32
    • Pull the side panels up and away from the printer to remove them.
    Pergunte ao FixBot
    Comentar
  6. HP Envy 7640 Printhead Replacement: passo 6, imagem 1 %32 HP Envy 7640 Printhead Replacement: passo 6, imagem 2 %32 HP Envy 7640 Printhead Replacement: passo 6, imagem 3 %32
    • Detach all the cables by gently pulling on them at their base in the direction of origin (for top connectors pull up and for bottom connectors pull down).
    Pergunte ao FixBot
    Comentar
  7. HP Envy 7640 Printhead Replacement: passo 7, imagem 1 %32
    • Remove the last two connectors found at the top of the motherboard by grasping the tan portion adjacent to the motherboard and pulling up.
    Pergunte ao FixBot
    Comentar
  8. HP Envy 7640 Printhead Replacement: passo 8, imagem 1 %32
    • Remove the four 7 mm screws from the motherboard by placing the Torx 9 screwdriver in the screw slots and turning counterclockwise.
    Pergunte ao FixBot
    Comentar
  9. HP Envy 7640 Printhead Replacement: passo 9, imagem 1 %32 HP Envy 7640 Printhead Replacement: passo 9, imagem 2 %32 HP Envy 7640 Printhead Replacement: passo 9, imagem 3 %32
    • Start to remove the motherboard from the device by lifting the left hand side of the motherboard out from the printer shell with minimal force.
    • Push the clip's head away from the motherboard to release the right hand side of the motherboard from the printer shell.
    • Remove the back connector by firmly grasping the tan portion of the connector adjacent to the motherboard and pulling in toward the printer to dislodge the motherboard.
    Pergunte ao FixBot
    Comentar
  10. HP Envy 7640 Printhead Replacement, Printhead: passo 10, imagem 1 %32 HP Envy 7640 Printhead Replacement, Printhead: passo 10, imagem 2 %32 HP Envy 7640 Printhead Replacement, Printhead: passo 10, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Place the T9 Torx screwdriver in the screw slot and turn counterclockwise to extract the single 14 mm screw.
    • Using the blunt tweezers, detach the spring by grasping the end attached to the fuser assembly and pulling out and away.
    • Using the blunt tweezers, remove the black, ribbed washer by prying away from the print rail.
    Pergunte ao FixBot
    Comentar
  11. HP Envy 7640 Printhead Replacement: passo 11, imagem 1 %32 HP Envy 7640 Printhead Replacement: passo 11, imagem 2 %32 HP Envy 7640 Printhead Replacement: passo 11, imagem 3 %32
    • Using the blunt tweezers, remove the spring via the same method outlined in the previous step.
    • Firmly grasp the print rail and gently guide it out of the slot in the fuser assembly by pulling away from the printer body.
    • Because this rail is what guides the printhead, it will be greased. Dress accordingly to avoid unwanted stains.
    • Because the printhead sits on this rail, be sure to brace the printhead as you retract the print rail to avoid any unwanted damage.
    Pergunte ao FixBot
    Comentar
  12. HP Envy 7640 Printhead Replacement: passo 12, imagem 1 %32 HP Envy 7640 Printhead Replacement: passo 12, imagem 2 %32 HP Envy 7640 Printhead Replacement: passo 12, imagem 3 %32
    • Place the T9 Torx screwdriver in the screw slot and turn counterclockwise to remove the single 12 mm screw.
    • Grasp the black, elastic band firmly and pull out and away from the white plastic pulley; the printhead can now be lifted out of the printer.
    Pergunte ao FixBot
    Comentar
Conclusão
Mani Movva
Membro desde: 01/23/18
229 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S1-G2, Livingston Winter 2018 Membro de Cal Poly, Team S1-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G2
3 Membros
Autoria de 10 guias
2Comentários do guia
What's the part number for the print head?
Doug - Responder Compartilhar
I have a HP Envy 7645, it prints B&W but not in color, at some point one of the colors was working, could it be the ribbon cable that connects the printer to the ink cartridge, any idea how to order this?
rallenfl - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 74
Ao todo: 10,176
