Ir para o conteúdo principal
HP Envy 700-030qe RAM Replacement
O que você precisa
    1. HP Envy 700-030qe RAM Replacement, RAM: passo 1, imagem 1 %32 HP Envy 700-030qe RAM Replacement, RAM: passo 1, imagem 2 %32 HP Envy 700-030qe RAM Replacement, RAM: passo 1, imagem 3 %32
      • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
      • Unscrew the 10.5mm screw on the left of the desktop using your hand.
      • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
      Pergunte ao FixBot
      Comentar
    2. HP Envy 700-030qe RAM Replacement: passo 2, imagem 1 %32 HP Envy 700-030qe RAM Replacement: passo 2, imagem 2 %32
      • You can now slide off the side panel of the desktop.
      • You should now have an opening on the side of your computer as shown in the second picture.
      • The location of the RAM is highlighted in red.
      Pergunte ao FixBot
      Comentar
    3. HP Envy 700-030qe RAM Replacement: passo 3, imagem 1 %32 HP Envy 700-030qe RAM Replacement: passo 3, imagem 2 %32
      • Undo the clips on each end of the chip as shown in the second picture.
      • Then you may carefully remove the RAM chips by pulling them out by their the ends.
      • Make sure you pull the chips out by the ends and not grabbing the entire thing. This may damage the chips.
      • Remember the slots that you take the RAM chips from. You must put the two replacement chips in the same slots.
      Pergunte ao FixBot
      Comentar
Conclusão
Sam Wheeler
Membro desde: 10/01/15
228 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-9, Maness Fall 2015 Membro de Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Membros
Autoria de 30 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 1,174
