Ir para o conteúdo principal
HP Envy 5660 LCD Replacement
O que você precisa
  1. HP Envy 5660 LCD Replacement, LCD: passo 1, imagem 1 %32
    • Lift the scanner to open up the printer cartridge access area.
    Pergunte ao FixBot
    Comentar
  2. HP Envy 5660 LCD Replacement: passo 2, imagem 1 %32 HP Envy 5660 LCD Replacement: passo 2, imagem 2 %32
    • Remove the two 12 mm screws with a T10 bit.
    Pergunte ao FixBot
    Comentar
  3. HP Envy 5660 LCD Replacement: passo 3, imagem 1 %32 HP Envy 5660 LCD Replacement: passo 3, imagem 2 %32 HP Envy 5660 LCD Replacement: passo 3, imagem 3 %32
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
    Pergunte ao FixBot
    Comentar
  4. HP Envy 5660 LCD Replacement: passo 4, imagem 1 %32 HP Envy 5660 LCD Replacement: passo 4, imagem 2 %32
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. HP Envy 5660 LCD Replacement: passo 5, imagem 1 %32 HP Envy 5660 LCD Replacement: passo 5, imagem 2 %32
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
    Pergunte ao FixBot
    Comentar
  6. HP Envy 5660 LCD Replacement: passo 6, imagem 1 %32
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Steakley
Membro desde: 01/23/18
790 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G6, Livingston Winter 2018 Membro de Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Membros
Autoria de 10 guias
2Comentários do guia
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Responder Compartilhar
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 47
Ao todo: 1,793
