Ir para o conteúdo principal
HP Envy 23-d060qd TouchSmart Fan Replacement
O que você precisa
  1. HP Envy 23-d060qd TouchSmart Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 2, imagem 1 %32
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 3, imagem 1 %32
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: passo 4, imagem 1 %32 HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: passo 4, imagem 2 %32
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate.
  5. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 5, imagem 1 %32 HP Envy 23-d060qd TouchSmart Fan Replacement: passo 5, imagem 2 %32
    • Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when you separate wired connections. Pulling on the wires can damage them.
  6. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 6, imagem 1 %32
    • Remove the three 8mm T15 screws from the fan.
  7. HP Envy 23-d060qd TouchSmart Fan Replacement: passo 7, imagem 1 %32
    • Pull the fan loose from the computer.
Conclusão
3 outras pessoas executaram este guia.
Zachary Dicks
Membro desde: 10/01/15
1.117 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 5-10, Maness Fall 2015 Membro de Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Duração total: 3,710
