Ir para o conteúdo principal
HP Elitebook x360 1040 G5 Battery Replacement
O que você precisa
  1. HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: passo 1, imagem 1 %32 HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: passo 1, imagem 2 %32
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Battery Replacement: passo 2, imagem 1 %32 HP Elitebook x360 1040 G5 Battery Replacement: passo 2, imagem 2 %32
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Battery Replacement, Battery: passo 3, imagem 1 %32 HP Elitebook x360 1040 G5 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Battery Replacement: passo 4, imagem 1 %32 HP Elitebook x360 1040 G5 Battery Replacement: passo 4, imagem 2 %32 HP Elitebook x360 1040 G5 Battery Replacement: passo 4, imagem 3 %32
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Corey Agena
Membro desde: 04/21/19
833 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S1-G4, Maness Spring 2019 Membro de Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 47
Duração total: 2,249
