Ir para o conteúdo principal
HP Elitebook 840 G1 Battery Replacement
O que você precisa
  1. HP Elitebook 840 G1 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
    Slide to your "other left", on this screen it would be to the right, to slide open the cover
    petunia8107 - Responder
    l’expression “Détachez le cache du loquet pour le retirer “ est ambigüe et source d’erreur, elle donne à penser qu’il faut retirer un “cache” qui serait sur le loquet.
    Ce qu’il faut c’est détacher le cache (la grande plaque où il y a la logo bleu) de la partie fixe sur laquelle se trouve le loquet. Pour ça il faut glisser une lame fine dans la fente entre le cache et la partie fixe.
    merci pour le tutoriel.
    Philippe Fayolle - Responder
    Bonjour Philippe,
    Vous avez bien raison ! J’ai adapté la traduction. Merci pour l’observation ! N’hésitez pas à corriger le texte la prochaine fois. Vous trouverez l’interface de traduction en cliquant sur Traduire en haut à droite de l’étape.
    Bonne réparation !
    Claire Miesch -
  2. HP Elitebook 840 G1 Battery Replacement: passo 2, imagem 1 %32
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  3. HP Elitebook 840 G1 Battery Replacement: passo 3, imagem 1 %32
    • Battery should easily be lifted up and out.
Conclusão
26 outras pessoas executaram este guia.
Ashley Williams
Membro desde: 08/27/15
2.398 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 5-3, Blackwell Fall 2015 Membro de USF Tampa, Team 5-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G3
Membros da 4
Autoria de 19 guias
2 comentários
Where do I buy another battery and how long does it last on the laptop? 4hr or more?
Vikshay Vuthavadoo - Responder
Passt auch für HP Elitebook 850 G2.
Die Anleitung und der Ersatzakku konnten auch bei einem HP Elitebook 850 G2 (Bezeichnung lt. Systeminfo des Notebooks) verwendet werden, das der Akku exakt der gleiche war (HP CM03)
Raller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 51
Últimos 30 dias: 239
Duração total: 77,164
