Introdução
This guide is meant to remedy a faulty fan. Signs of a defective fan include overheating, rapid battery power depletion or grinding noises. This guide involves many small parts, do not lose track of these because they are necessary for reassembly.
O que você precisa
Place computer with the screen down on a flat surface.
Push the two locking latches to the unlocked position.
Push the cover toward the top of the computer and lift up.
Press locking latch on the bottom of the base of the stand.
Pull the plastic cover off of the stand.
Disconnect these two power connectors on the motherboard, one connector is white and the other is black. You can identify the correct wires by their braided colors: red, yellow, blue, and black.
5 outras pessoas executaram este guia.
