Ir para o conteúdo principal
HP EliteBook x360 830 G7 Solid State Drive Replacement
O que você precisa
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: passo 1, imagem 1 %32 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: passo 1, imagem 2 %32
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: passo 2, imagem 1 %32
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, imagem 1 %32 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, imagem 2 %32 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: passo 4, imagem 1 %32
    • Gently pull the SSD free from the M.2 socket.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 89
Ao todo: 1,578
