Ir para o conteúdo principal
HP EliteBook x360 830 G6 Heatsink Replacement
O que você precisa
  1. HP EliteBook x360 830 G6 Heatsink Replacement, Unfasten the back cover: passo 1, imagem 1 %32
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Heatsink Replacement, Release the clips: passo 2, imagem 1 %32 HP EliteBook x360 830 G6 Heatsink Replacement, Release the clips: passo 2, imagem 2 %32
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Heatsink Replacement, Release the remaining clips: passo 3, imagem 1 %32 HP EliteBook x360 830 G6 Heatsink Replacement, Release the remaining clips: passo 3, imagem 2 %32
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Heatsink Replacement, Remove the back cover: passo 4, imagem 1 %32 HP EliteBook x360 830 G6 Heatsink Replacement, Remove the back cover: passo 4, imagem 2 %32 HP EliteBook x360 830 G6 Heatsink Replacement, Remove the back cover: passo 4, imagem 3 %32
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Heatsink Replacement, Disconnect the battery: passo 5, imagem 1 %32 HP EliteBook x360 830 G6 Heatsink Replacement, Disconnect the battery: passo 5, imagem 2 %32 HP EliteBook x360 830 G6 Heatsink Replacement, Disconnect the battery: passo 5, imagem 3 %32
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Heatsink Replacement, Heatsink: passo 6, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove each of the four 3 mm screws at each corner of the heatsink.
  7. HP EliteBook x360 830 G6 Heatsink Replacement: passo 7, imagem 1 %32 HP EliteBook x360 830 G6 Heatsink Replacement: passo 7, imagem 2 %32 HP EliteBook x360 830 G6 Heatsink Replacement: passo 7, imagem 3 %32
    • Gently pull the heatsink off of the motherboard.
    • Be sure to clean the old thermal paste and apply new thermal paste before replacing the heatsink.
    • Tighten the replacement heatsink screws in an "X" pattern.
Conclusão
Brody Reder
Membro desde: 04/02/24
301 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-3, Harley Spring 2024 Membro de IUPUI, Team 3-3, Harley Spring 2024
IUPUI-HARLEY-S24S3G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 35
