Ir para o conteúdo principal
HP EliteBook x360 1030 G3 Battery Replacement
O que você precisa
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: passo 2, imagem 1 %32
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: passo 3, imagem 1 %32
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: passo 4, imagem 1 %32 HP EliteBook x360 1030 G3 Battery Replacement: passo 4, imagem 2 %32
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Battery Replacement: passo 5, imagem 1 %32
    • Gently lift the battery out of its place.
Conclusão
8 outras pessoas executaram este guia.
Pablo Arriola
Membro desde: 04/22/19
504 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S2-G9, Maness Spring 2019 Membro de Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
Membros da 4
Autoria de 16 guias
4 comentários
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - Responder
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - Responder
Thank you. very useful.
mustapha ELABED - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 47
Últimos 30 dias: 159
Duração total: 12,029
