Ir para o conteúdo principal
HP EliteBook 8560w Hard Drive Replacement
O que você precisa
  1. HP EliteBook 8560w Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP EliteBook 8560w Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Hard Drive Replacement: passo 2, imagem 1 %32
    • Pull the battery out.
  3. HP EliteBook 8560w Hard Drive Replacement, Back Panel: passo 3, imagem 1 %32 HP EliteBook 8560w Hard Drive Replacement, Back Panel: passo 3, imagem 2 %32
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Hard Drive Replacement: passo 4, imagem 1 %32
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 HP EliteBook 8560w Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    • Make sure your device is powered off and its battery removed.
    • Remove the four M2.5x8mm screws with Phillips #0 screwdriver and lift up the panel to access your Hard Drive.
  6. HP EliteBook 8560w Hard Drive Replacement: passo 6, imagem 1 %32 HP EliteBook 8560w Hard Drive Replacement: passo 6, imagem 2 %32 HP EliteBook 8560w Hard Drive Replacement: passo 6, imagem 3 %32
    • Remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Slide the hard drive to the left and lift it to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 41
Ao todo: 1,900
