Ir para o conteúdo principal
HP EliteBook 8530w Fan Replacement
O que você precisa
    1. HP EliteBook 8530w Fan Replacement, Battery: passo 1, imagem 1 %32 HP EliteBook 8530w Fan Replacement, Battery: passo 1, imagem 2 %32
      • Turn the laptop off then place it down so that the back is facing up.
      • Slide the battery release switch to the left and hold it there.
      Pergunte ao FixBot
      Comentar
    2. HP EliteBook 8530w Fan Replacement: passo 2, imagem 1 %32 HP EliteBook 8530w Fan Replacement: passo 2, imagem 2 %32
      • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
      • Once the battery is removed from the laptop, you may release the switch.
      • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
      Pergunte ao FixBot
      Comentar
    1. HP EliteBook 8530w Fan Replacement, Fan: passo 3, imagem 1 %32
      • Unscrew the two screws from the center panel with a Phillips #00 screwdriver.
      • These screws should have a keyboard icon stamped next to them.
      Pergunte ao FixBot
      Comentar
    2. HP EliteBook 8530w Fan Replacement: passo 4, imagem 1 %32 HP EliteBook 8530w Fan Replacement: passo 4, imagem 2 %32 HP EliteBook 8530w Fan Replacement: passo 4, imagem 3 %32
      • Flip the laptop over then open the lid.
      • Slide the four tabs at the top of the keyboard towards you with your finger.
      • Wedge a finger or spudger in the top corner of the keyboard and hinge it forward to reveal the backside.
      • Do not try to pull the keyboard out of the laptop. There are still cables connected to it that can easily be damaged.
      Pergunte ao FixBot
      Comentar
    3. HP EliteBook 8530w Fan Replacement: passo 5, imagem 1 %32 HP EliteBook 8530w Fan Replacement: passo 5, imagem 2 %32 HP EliteBook 8530w Fan Replacement: passo 5, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Use a Torx TR7 screwdriver to remove the three screws holding down the fan.
      • Gently remove the fan connector that plugs into the motherboard.
      • Note: It can help to use something like tweezers to remove the connector if you are having trouble.
      • Remove the fan.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 17
Ao todo: 1,060
