Ir para o conteúdo principal
HP EliteBook 850 G3 WiFi Card Replacement
O que você precisa
  1. HP EliteBook 850 G3 WiFi Card Replacement, WiFi Card: passo 1, imagem 1 %32
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 WiFi Card Replacement: passo 2, imagem 1 %32 HP EliteBook 850 G3 WiFi Card Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 WiFi Card Replacement: passo 3, imagem 1 %32 HP EliteBook 850 G3 WiFi Card Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 WiFi Card Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 WiFi Card Replacement: passo 5, imagem 1 %32 HP EliteBook 850 G3 WiFi Card Replacement: passo 5, imagem 2 %32
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 WiFi Card Replacement: passo 6, imagem 1 %32 HP EliteBook 850 G3 WiFi Card Replacement: passo 6, imagem 2 %32 HP EliteBook 850 G3 WiFi Card Replacement: passo 6, imagem 3 %32
    • Disconnect the coaxial cables wires from the WiFi card.
Conclusão
Annabeth Grover
Membro desde: 10/10/19
922 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G1, Leahy Fall 2019 Membro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
Membros da 4
Autoria de 6 guias
Um comentário
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
MV9000 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 26
Duração total: 1,531
