Ir para o conteúdo principal
HP EliteBook 850 G3 Motherboard Replacement
O que você precisa
  1. HP EliteBook 850 G3 Motherboard Replacement, WiFi Card: passo 1, imagem 1 %32
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 Motherboard Replacement: passo 2, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Motherboard Replacement: passo 3, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 Motherboard Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 Motherboard Replacement: passo 5, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 5, imagem 2 %32
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 Motherboard Replacement: passo 6, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 6, imagem 2 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 6, imagem 3 %32
    • Disconnect the coaxial cables wires from the WiFi card.
  7. HP EliteBook 850 G3 Motherboard Replacement, Fan: passo 7, imagem 1 %32
    • Gently unclip the plastic frame.
  8. HP EliteBook 850 G3 Motherboard Replacement: passo 8, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 8, imagem 2 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 8, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  9. HP EliteBook 850 G3 Motherboard Replacement: passo 9, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 9, imagem 2 %32
    • Carefully remove the connector for the fan.
  10. HP EliteBook 850 G3 Motherboard Replacement: passo 10, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 10, imagem 2 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 10, imagem 3 %32
    • Carefully remove the fan and heatsink assembly from the laptop.
    • Slide out RAM (not pictured).
  11. HP EliteBook 850 G3 Motherboard Replacement: passo 12, imagem 1 %32
    • Use a #00 Phillips screwdriver to remove twelve 5.7 mm screws from the motherboard.
  12. HP EliteBook 850 G3 Motherboard Replacement: passo 13, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 13, imagem 2 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 13, imagem 3 %32
    • Remove the wire connectors.
  13. HP EliteBook 850 G3 Motherboard Replacement: passo 14, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 14, imagem 2 %32
    • Jiggle the motherboard until the ports (ie. headphone jack) come out from the sides and you can lift it up.
  14. HP EliteBook 850 G3 Motherboard Replacement: passo 15, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 15, imagem 2 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 15, imagem 3 %32
    • Disconnect the wires underneath.
  15. HP EliteBook 850 G3 Motherboard Replacement: passo 16, imagem 1 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 16, imagem 2 %32 HP EliteBook 850 G3 Motherboard Replacement: passo 16, imagem 3 %32
    • Take out the motherboard.
Conclusão
Annabeth Grover
Membro desde: 10/10/19
922 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G1, Leahy Fall 2019 Membro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 51
Duração total: 3,316
