Ir para o conteúdo principal
HP EliteBook 850 G3 Fan Replacement
O que você precisa
  1. HP EliteBook 850 G3 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: passo 2, imagem 1 %32 HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Fan Replacement: passo 3, imagem 1 %32 HP EliteBook 850 G3 Fan Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: passo 4, imagem 1 %32 HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Fan Replacement, Lift the battery: passo 5, imagem 1 %32 HP EliteBook 850 G3 Fan Replacement, Lift the battery: passo 5, imagem 2 %32 HP EliteBook 850 G3 Fan Replacement, Lift the battery: passo 5, imagem 3 %32
    • Lift and pull the flap located at the top of the battery to remove it.
  6. HP EliteBook 850 G3 Fan Replacement, Fan: passo 6, imagem 1 %32
    • Gently unclip the plastic frame.
  7. HP EliteBook 850 G3 Fan Replacement: passo 7, imagem 1 %32 HP EliteBook 850 G3 Fan Replacement: passo 7, imagem 2 %32 HP EliteBook 850 G3 Fan Replacement: passo 7, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  8. HP EliteBook 850 G3 Fan Replacement: passo 8, imagem 1 %32 HP EliteBook 850 G3 Fan Replacement: passo 8, imagem 2 %32
    • Carefully remove the connector for the fan.
  9. HP EliteBook 850 G3 Fan Replacement: passo 9, imagem 1 %32 HP EliteBook 850 G3 Fan Replacement: passo 9, imagem 2 %32 HP EliteBook 850 G3 Fan Replacement: passo 9, imagem 3 %32
    • Carefully remove the fan and heatsink assembly from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Annabeth Grover
Membro desde: 10/10/19
922 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G1, Leahy Fall 2019 Membro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 40
Duração total: 2,420
