Ir para o conteúdo principal
HP EliteBook 840 G6 Disassembly
O que você precisa
  1. HP EliteBook 840 G6 Disassembly, Identify the screws: passo 1, imagem 1 %32
    • Identify the screws.
    Pour voir au changer la batterie comment faire ?
    Brahim Jelti - Responder
  2. HP EliteBook 840 G6 Disassembly, Unscrew the screws: passo 2, imagem 1 %32 HP EliteBook 840 G6 Disassembly, Unscrew the screws: passo 2, imagem 2 %32
    • Unscrew the screws.
    • Screws are attached to the back panel.
  3. HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: passo 3, imagem 1 %32 HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: passo 3, imagem 2 %32 HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    iFixit Opening Tool
    $1.99
    • Use your fingernail or the iFixit Opening Tool.
    • Start on the far side when prying apart.
    • Open the computer.
    • The display should face the table.
    • Separate gently the back cover from the front panel (keyboard panel).
  4. HP EliteBook 840 G6 Disassembly, Open back and front cover: passo 4, imagem 1 %32 HP EliteBook 840 G6 Disassembly, Open back and front cover: passo 4, imagem 2 %32 HP EliteBook 840 G6 Disassembly, Open back and front cover: passo 4, imagem 3 %32
    • Open each side gently (keyboard panel is facing up, the back cover is facing down).
    • Store the back cover.
  5. HP EliteBook 840 G6 Disassembly, End result: passo 5, imagem 1 %32
    • You now have access to the mainboard.
    Note that the battery is attached using different screws and you need a corresponding screw driver
    Fritz Rothacher - Responder
Conclusão
7 outras pessoas executaram este guia.
Eric M.
Membro desde: 12/27/21
491 Reputação
Autoria de 2 guias
2Comentários do guia
Are the 6 silver-colored screws holding the back cover on all the same length?
David Cary - Responder
The central screw has a different size.
Eric M. - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 90
Últimos 30 dias: 426
Ao todo: 9,276
