Introdução
The following instructions will explain how to safely remove the HP EliteBook 745 G2’s Wi-Fi Chip. A Wi-Fi chip receives a wireless signal that enables you to access internet. If you are having connectivity issues, use this troubleshooting guide. If you are still having connectivity issues after troubleshooting, you may need to replace your Wi-Fi chip.
Before you begin, read this guide for instructions on using the anti-static wrist strap listed under tools needed for Wi-Fi chip replacement. It is important to follow steps 1-3 to remove the battery before proceeding further. The electronics inside of the computer are fragile and require caution when handling.
O que você precisa
Gently place the laptop down on a suitable workplace with the back of the laptop facing up
Ferramenta utilizada neste passo:Anti-Static Wrist Strap$7.95
Attach the anti-static wrist strap to any metal piece on the computer to prevent electrical damage.
