Ir para o conteúdo principal
HP EliteBook 745 G2 RAM Chip Replacement
O que você precisa
    1. HP EliteBook 745 G2 RAM Chip Replacement, Battery: passo 1, imagem 1 %32
      • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
      Pergunte ao FixBot
      Comentar
    2. HP EliteBook 745 G2 RAM Chip Replacement: passo 2, imagem 1 %32 HP EliteBook 745 G2 RAM Chip Replacement: passo 2, imagem 2 %32
      • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
      Pergunte ao FixBot
      Comentar
    3. HP EliteBook 745 G2 RAM Chip Replacement: passo 3, imagem 1 %32 HP EliteBook 745 G2 RAM Chip Replacement: passo 3, imagem 2 %32
      • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
      Pergunte ao FixBot
      Comentar
    1. HP EliteBook 745 G2 RAM Chip Replacement, RAM Chip: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      Anti-Static Wrist Strap
      $7.95
      Pergunte ao FixBot
      Comentar
    2. HP EliteBook 745 G2 RAM Chip Replacement: passo 5, imagem 1 %32
      • Using the spudger, gently press down on the tabs holding the chip to release it. Repeat this step for the other chip.
      Pergunte ao FixBot
      Comentar
    3. HP EliteBook 745 G2 RAM Chip Replacement: passo 6, imagem 1 %32
      • Grab the chip and lift it away from the laptop at a 45 degree angle.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 816
