Ir para o conteúdo principal
HP EliteBook 745 G2 Hard Drive Replacement
O que você precisa
  1. HP EliteBook 745 G2 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 Hard Drive Replacement: passo 2, imagem 1 %32 HP EliteBook 745 G2 Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 Hard Drive Replacement: passo 3, imagem 1 %32 HP EliteBook 745 G2 Hard Drive Replacement: passo 3, imagem 2 %32
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
  4. HP EliteBook 745 G2 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • The hard drive is located to the left of the battery. To remove the hard drive firmly pull to the right until the drive is free from its attachment port.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 1,988
