Ir para o conteúdo principal
HP EliteBook 1040 G4 Speakers Replacement
O que você precisa
  1. HP EliteBook 1040 G4 Speakers Replacement, Back Cover: passo 1, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Speakers Replacement: passo 2, imagem 1 %32 HP EliteBook 1040 G4 Speakers Replacement: passo 2, imagem 2 %32
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Speakers Replacement, Battery: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Speakers Replacement: passo 4, imagem 1 %32 HP EliteBook 1040 G4 Speakers Replacement: passo 4, imagem 2 %32
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Speakers Replacement: passo 5, imagem 1 %32 HP EliteBook 1040 G4 Speakers Replacement: passo 5, imagem 2 %32
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Speakers Replacement, Speakers: passo 6, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the four black 6 mm screws securing the speakers to the device.
  7. HP EliteBook 1040 G4 Speakers Replacement: passo 7, imagem 1 %32
    • Disconnect the pin connector from the right side of the speaker assembly.
  8. HP EliteBook 1040 G4 Speakers Replacement: passo 8, imagem 1 %32
    • Carefully remove the red and black wires from the black clips in between the two speakers.
  9. HP EliteBook 1040 G4 Speakers Replacement: passo 9, imagem 1 %32
    • Remove the speakers from the device.
Conclusão
Hannah DiMartino
Membro desde: 09/28/21
395 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 4-1, Hunter Fall 2021 Membro de Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 484
