Ir para o conteúdo principal
HP Elite x2 1012 G2 Screen Replacement
O que você precisa
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: passo 2, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 2, imagem 2 %32 HP Elite x2 1012 G2 Screen Replacement: passo 2, imagem 3 %32
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: passo 3, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 3, imagem 2 %32
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Screen Replacement: passo 4, imagem 1 %32
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: passo 5, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 5, imagem 2 %32 HP Elite x2 1012 G2 Screen Replacement: passo 5, imagem 3 %32
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: passo 6, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 6, imagem 2 %32
    • Remove the screen by gently lifting it off of the device.
Conclusão
3 outras pessoas executaram este guia.
Noah Stapp
Membro desde: 04/18/18
731 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G5, Livingston Spring 2018 Membro de Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
Membros da 4
Autoria de 13 guias
5 comentários
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - Responder
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - Responder
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - Responder
The touch stopped working after the replacement. Any suggestions?
el._.msn - Responder
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 28
Últimos 30 dias: 121
Duração total: 8,411
