Ir para o conteúdo principal
HP Deskjet D1660 Encoder Strip Replacement
O que você precisa
  1. HP Deskjet D1660 Encoder Strip Replacement, Encoder Strip: passo 1, imagem 1 %32
    • Remove the back two 14.0 mm Torx #10 screws.
    Pergunte ao FixBot
    Comentar
  2. HP Deskjet D1660 Encoder Strip Replacement: passo 2, imagem 1 %32
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
    Pergunte ao FixBot
    Comentar
  3. HP Deskjet D1660 Encoder Strip Replacement: passo 3, imagem 1 %32
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
    Pergunte ao FixBot
    Comentar
  4. HP Deskjet D1660 Encoder Strip Replacement: passo 4, imagem 1 %32 HP Deskjet D1660 Encoder Strip Replacement: passo 4, imagem 2 %32 HP Deskjet D1660 Encoder Strip Replacement: passo 4, imagem 3 %32
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
    Pergunte ao FixBot
    Comentar
  5. HP Deskjet D1660 Encoder Strip Replacement: passo 5, imagem 1 %32 HP Deskjet D1660 Encoder Strip Replacement: passo 5, imagem 2 %32 HP Deskjet D1660 Encoder Strip Replacement: passo 5, imagem 3 %32
    • Looking at the printer from the front, carefully unhook the encoder strip from the left side.
    • Pull the strip to the left and push a little to unhook the strip.
    • Do the same thing on the other side by pulling to the right and pushing a little.
    • Pull the strip completely out from the cartridge holder.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 1-41, Maness Winter 2014 Membro de Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 70
Ao todo: 5,469
