Ir para o conteúdo principal
HP Deskjet 1000 J110a Paper Control Sensor Replacement
O que você precisa
    1. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: passo 1, imagem 1 %32 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: passo 1, imagem 2 %32 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: passo 1, imagem 3 %32
      • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
      Pergunte ao FixBot
      Comentar
    2. HP Deskjet 1000 J110a Paper Control Sensor Replacement: passo 2, imagem 1 %32 HP Deskjet 1000 J110a Paper Control Sensor Replacement: passo 2, imagem 2 %32 HP Deskjet 1000 J110a Paper Control Sensor Replacement: passo 2, imagem 3 %32
      • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
      Pergunte ao FixBot
      Comentar
    3. HP Deskjet 1000 J110a Paper Control Sensor Replacement: passo 3, imagem 1 %32
      • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
      Pergunte ao FixBot
      Comentar
    1. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: passo 4, imagem 1 %32 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: passo 4, imagem 2 %32 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Locate the paper control sensor.
      • You can find the sensor, with the back of the printer facing you, on the right, and in front of the main circuit board. The paper control sensor will also be attached to a small circuit board. You will be replacing this circuit board.
      • Locate and unplug the connector which connects the sensor board to the main circuit board.
      • Use tweezers if unplugging by hand is too difficult.
      Pergunte ao FixBot
      Comentar
    2. HP Deskjet 1000 J110a Paper Control Sensor Replacement: passo 5, imagem 1 %32 HP Deskjet 1000 J110a Paper Control Sensor Replacement: passo 5, imagem 2 %32
      • Locate and remove the 8mm screw with a screwdriver and the T10 torx bit, then remove the paper control sensor board.
      • In this picture, the main circuit board is removed. It is not necessary to remove the main circuit board unless the paper control sensor is not the only part being replaced.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S5-G3, Passmore Spring 2018 Membro de USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 61
Ao todo: 2,993
