Ir para o conteúdo principal
HP Compaq nc8430 RAM Replacement
O que você precisa
  1. HP Compaq nc8430 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
    Pergunte ao FixBot
    Comentar
  2. HP Compaq nc8430 RAM Replacement: passo 2, imagem 1 %32
    • Slide up against the three lines the battery has.
    Pergunte ao FixBot
    Comentar
  3. HP Compaq nc8430 RAM Replacement: passo 3, imagem 1 %32
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
    Pergunte ao FixBot
    Comentar
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: passo 4, imagem 1 %32
    • Completely shut down the device and unplug any adapters and chords that are connected.
    Pergunte ao FixBot
    Comentar
  5. HP Compaq nc8430 RAM Replacement: passo 5, imagem 1 %32
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
    Pergunte ao FixBot
    Comentar
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: passo 6, imagem 1 %32
    • Locate the RAM after you remove the covering.
    Pergunte ao FixBot
    Comentar
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: passo 7, imagem 1 %32
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
    Pergunte ao FixBot
    Comentar
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: passo 8, imagem 1 %32
    • Place your fingers firmly on the RAM and pull it up.
    Pergunte ao FixBot
    Comentar
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: passo 9, imagem 1 %32
    • Place fingers firmly on RAM and pull it to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
bryan ingram
Membro desde: 03/27/17
101 Reputação
Autoria de 1 guia
1Comentário do guia
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 1,082
