Ir para o conteúdo principal
HP Compaq nc6400 RAM Replacement
O que você precisa
  1. HP Compaq nc6400 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off and unplug laptop.
    Pergunte ao FixBot
    Comentar
  2. HP Compaq nc6400 RAM Replacement: passo 2, imagem 1 %32
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    Pergunte ao FixBot
    Comentar
  3. HP Compaq nc6400 RAM Replacement: passo 3, imagem 1 %32
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    Pergunte ao FixBot
    Comentar
  4. HP Compaq nc6400 RAM Replacement: passo 4, imagem 1 %32
    • Once both the battery locks are unlocked, slide the battery out to remove.
    Pergunte ao FixBot
    Comentar
  5. HP Compaq nc6400 RAM Replacement, RAM: passo 5, imagem 1 %32 HP Compaq nc6400 RAM Replacement, RAM: passo 5, imagem 2 %32
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
    Pergunte ao FixBot
    Comentar
  6. HP Compaq nc6400 RAM Replacement: passo 6, imagem 1 %32
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
    Pergunte ao FixBot
    Comentar
  7. HP Compaq nc6400 RAM Replacement: passo 7, imagem 1 %32 HP Compaq nc6400 RAM Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
    Pergunte ao FixBot
    Comentar
  8. HP Compaq nc6400 RAM Replacement: passo 8, imagem 1 %32
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
    Pergunte ao FixBot
    Comentar
  9. HP Compaq nc6400 RAM Replacement: passo 9, imagem 1 %32 HP Compaq nc6400 RAM Replacement: passo 9, imagem 2 %32
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Luis Vazquez
Membro desde: 09/24/13
401 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-6, Forte Fall 2013 Membro de Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 31
Ao todo: 4,867
