Ir para o conteúdo principal
HP Compaq nc6400 Bluetooth Module Replacement
O que você precisa
    1. HP Compaq nc6400 Bluetooth Module Replacement, Battery: passo 1, imagem 1 %32
      • Turn off and unplug laptop.
      Pergunte ao FixBot
      Comentar
    2. HP Compaq nc6400 Bluetooth Module Replacement: passo 2, imagem 1 %32
      • Locate the battery lock below the battery labeled one.
      • Slide the lock all the way to the left to release the left lock of the battery.
      Pergunte ao FixBot
      Comentar
    3. HP Compaq nc6400 Bluetooth Module Replacement: passo 3, imagem 1 %32
      • Locate the lock labeled two at the bottom right corner below the battery.
      • Slide and hold the lock to the left.
      Pergunte ao FixBot
      Comentar
    4. HP Compaq nc6400 Bluetooth Module Replacement: passo 4, imagem 1 %32
      • Once both the battery locks are unlocked, slide the battery out to remove.
      Pergunte ao FixBot
      Comentar
    1. HP Compaq nc6400 Bluetooth Module Replacement, Bluetooth Module: passo 5, imagem 1 %32
      • Flip the computer top down and locate the second to-the-right 1.2 Philips #1 screw in the bottom-left corner.
      • Remove the screw.
      Pergunte ao FixBot
      Comentar
    2. HP Compaq nc6400 Bluetooth Module Replacement: passo 6, imagem 1 %32 HP Compaq nc6400 Bluetooth Module Replacement: passo 6, imagem 2 %32 HP Compaq nc6400 Bluetooth Module Replacement: passo 6, imagem 3 %32
      • Lift the right side of the Bluetooth Module cover upwards.
      • Slide the spudger under the lifted case, and slide it left towards the closed end. The case will pop open and be removed from the compartment.
      Pergunte ao FixBot
      Comentar
    3. HP Compaq nc6400 Bluetooth Module Replacement: passo 7, imagem 1 %32
      • Locate the Bluetooth Module after removing the cover.
      • Using the spudger, push the module to the right (i.e. towards the screw hole).
      • Pull outwards and remove bluetooth module and wire from casing.
      Pergunte ao FixBot
      Comentar
    4. HP Compaq nc6400 Bluetooth Module Replacement: passo 8, imagem 1 %32 HP Compaq nc6400 Bluetooth Module Replacement: passo 8, imagem 2 %32
      • Once the module and wire are completely outside of the casing, gently pull apart the wire from the module clip.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 14-6, Forte Fall 2013 Membro de Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Membros
Autoria de 25 guias
1Comentário do guia
Hi,
My HP nx9420 did not have the Bluetooth. I wish to install one. I got one from my old HP nx9420. it Part Number is 397922-001 but the actual laptop says it requires the 409993-001 are these module the same ?
thanks
Alain
Alain Bastien - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 38
Ao todo: 2,662
