Ir para o conteúdo principal
HP Compaq Presario CQ56-110US Keyboard Replacement
O que você precisa
Vídeo de Apresentação
  1. HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
    • Push the latch to the unlocked position.
  2. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 2, imagem 1 %32
    • Gently take out the battery.
  3. HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • On the back panel of the laptop are two screws which have a keyboard symbol next to them.
    • Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
  4. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 4, imagem 1 %32 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 4, imagem 2 %32
    • From left to right, unscrew the 5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
  5. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 5, imagem 1 %32 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel using a plastic opening tool.
  6. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 6, imagem 1 %32
    • Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
  7. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 7, imagem 1 %32
    • Flip the laptop back over and lift the lid to expose the keyboard.
  8. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 8, imagem 1 %32 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to pry up the keyboard.
  9. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 9, imagem 1 %32 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 9, imagem 2 %32
    • Once the keyboard is lifted, disconnect the band.
Conclusão
3 outras pessoas executaram este guia.
Iyonna L. Tynes
Membro desde: 02/15/17
446 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-4, Eyestone Spring 2017 Membro de USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
4 Membros
Autoria de 5 guias
1Comentário do guia
Difficulty HARD ? oh please… please change to EASY… just some screws?
Assembler Computer - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 37
Ao todo: 3,626
