Ir para o conteúdo principal
HP Compaq C700 Fan Replacement
O que você precisa
  1. HP Compaq C700 Fan Replacement, Keyboard: passo 1, imagem 1 %32
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
    Pergunte ao FixBot
    Comentar
  2. HP Compaq C700 Fan Replacement: passo 2, imagem 1 %32 HP Compaq C700 Fan Replacement: passo 2, imagem 2 %32 HP Compaq C700 Fan Replacement: passo 2, imagem 3 %32
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
    Pergunte ao FixBot
    Comentar
  3. HP Compaq C700 Fan Replacement: passo 3, imagem 1 %32
    • Gently lift up and remove the keyboard.
    Pergunte ao FixBot
    Comentar
  4. HP Compaq C700 Fan Replacement, Fan: passo 4, imagem 1 %32
    • Turn the laptop over so that you see the bottom.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver
    Pergunte ao FixBot
    Comentar
  5. HP Compaq C700 Fan Replacement: passo 5, imagem 1 %32
    • After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
    Pergunte ao FixBot
    Comentar
  6. HP Compaq C700 Fan Replacement: passo 6, imagem 1 %32
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
    Pergunte ao FixBot
    Comentar
  7. HP Compaq C700 Fan Replacement: passo 7, imagem 1 %32
    • Remove the covering that houses the RAM modules.
    Pergunte ao FixBot
    Comentar
  8. HP Compaq C700 Fan Replacement: passo 8, imagem 1 %32
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
    Pergunte ao FixBot
    Comentar
  9. HP Compaq C700 Fan Replacement: passo 9, imagem 1 %32
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
    Pergunte ao FixBot
    Comentar
  10. HP Compaq C700 Fan Replacement: passo 10, imagem 1 %32
    • Gently lift and pull out the card.
    Pergunte ao FixBot
    Comentar
  11. HP Compaq C700 Fan Replacement: passo 11, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the power button connector wire. (This can be found where the keyboard sits.)
    • Using the tweezers, unhook the wire.
    Pergunte ao FixBot
    Comentar
  12. HP Compaq C700 Fan Replacement: passo 12, imagem 1 %32 HP Compaq C700 Fan Replacement: passo 12, imagem 2 %32
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
    Pergunte ao FixBot
    Comentar
  13. HP Compaq C700 Fan Replacement: passo 13, imagem 1 %32 HP Compaq C700 Fan Replacement: passo 13, imagem 2 %32
    • Unplug the remaining wires using the tweezers.
    Pergunte ao FixBot
    Comentar
  14. HP Compaq C700 Fan Replacement: passo 14, imagem 1 %32
    • Gently pull out the three wires.
    Pergunte ao FixBot
    Comentar
  15. HP Compaq C700 Fan Replacement: passo 15, imagem 1 %32 HP Compaq C700 Fan Replacement: passo 15, imagem 2 %32
    • Locate the four 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
    Pergunte ao FixBot
    Comentar
  16. HP Compaq C700 Fan Replacement: passo 16, imagem 1 %32
    • Unhook the display connector wire.
    Pergunte ao FixBot
    Comentar
  17. HP Compaq C700 Fan Replacement: passo 17, imagem 1 %32
    • Gently disconnect the display by pulling it upwards.
    Pergunte ao FixBot
    Comentar
  18. HP Compaq C700 Fan Replacement: passo 18, imagem 1 %32
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
    Pergunte ao FixBot
    Comentar
  19. HP Compaq C700 Fan Replacement: passo 19, imagem 1 %32
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
    Pergunte ao FixBot
    Comentar
  20. HP Compaq C700 Fan Replacement: passo 20, imagem 1 %32
    • Locate and unplug the touchpad connection using the tweezers.
    Pergunte ao FixBot
    Comentar
  21. HP Compaq C700 Fan Replacement: passo 21, imagem 1 %32 HP Compaq C700 Fan Replacement: passo 21, imagem 2 %32 HP Compaq C700 Fan Replacement: passo 21, imagem 3 %32
    • Using the Opening tool, gently pry up the cover and remove it.
    Pergunte ao FixBot
    Comentar
  22. HP Compaq C700 Fan Replacement: passo 22, imagem 1 %32
    • Unplug the fan wire connection using the tweezers.
    Pergunte ao FixBot
    Comentar
  23. HP Compaq C700 Fan Replacement: passo 23, imagem 1 %32
    • Locate the 3 mm Phillips head screw.
    • Unscrew it using the PH0 screwdriver.
    Pergunte ao FixBot
    Comentar
  24. HP Compaq C700 Fan Replacement: passo 24, imagem 1 %32 HP Compaq C700 Fan Replacement: passo 24, imagem 2 %32
    • Using the opening tool, gently pry up and remove the fan.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 1,723
