Ir para o conteúdo principal
HP Compaq C700 Battery Replacement
  1. HP Compaq C700 Battery Replacement, Battery: passo 1, imagem 1 %32
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
    Pergunte ao FixBot
    Comentar
  2. HP Compaq C700 Battery Replacement: passo 2, imagem 1 %32
    • On the underside of the laptop, locate the sliding lock that keeps the battery in place.
    • Using your finger, slide the battery lock to the left to unlock the battery. Once the battery is unlocked, it is free to be removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Membros
Autoria de 6 guias
1Comentário do guia
thanks - appreciate this advice as I wasn’t able to get the battery out and thought I was missing something, but then I just tried harder!
Albert Einstein - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 46
Ao todo: 1,768
