Ir para o conteúdo principal
HP Compaq 6710b Screen Replacement
O que você precisa
  1. HP Compaq 6710b Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
    Pergunte ao FixBot
    Comentar
  2. HP Compaq 6710b Screen Replacement, Keyboard: passo 2, imagem 1 %32 HP Compaq 6710b Screen Replacement, Keyboard: passo 2, imagem 2 %32 HP Compaq 6710b Screen Replacement, Keyboard: passo 2, imagem 3 %32
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
    Pergunte ao FixBot
    Comentar
  3. HP Compaq 6710b Screen Replacement: passo 3, imagem 1 %32
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
    Pergunte ao FixBot
    Comentar
  4. HP Compaq 6710b Screen Replacement: passo 4, imagem 1 %32 HP Compaq 6710b Screen Replacement: passo 4, imagem 2 %32
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    Pergunte ao FixBot
    Comentar
  5. HP Compaq 6710b Screen Replacement: passo 5, imagem 1 %32
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
    Pergunte ao FixBot
    Comentar
  6. HP Compaq 6710b Screen Replacement, Power Button Panel: passo 6, imagem 1 %32
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
    Pergunte ao FixBot
    Comentar
  7. HP Compaq 6710b Screen Replacement: passo 7, imagem 1 %32 HP Compaq 6710b Screen Replacement: passo 7, imagem 2 %32 HP Compaq 6710b Screen Replacement: passo 7, imagem 3 %32
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
    Pergunte ao FixBot
    Comentar
  8. HP Compaq 6710b Screen Replacement, Screen: passo 8, imagem 1 %32
    • Using a flathead screwdriver, work both sides of the connector next to the fan and take it out.
    Pergunte ao FixBot
    Comentar
  9. HP Compaq 6710b Screen Replacement: passo 9, imagem 1 %32
    • Using the T9 Torx screwdriver, remove one 7mm screw on the left hinge.
    • We recommend replacing this screw shortly after removing the cable as it helps hold the hinge to the lower half of the laptop.
    Pergunte ao FixBot
    Comentar
  10. HP Compaq 6710b Screen Replacement: passo 10, imagem 1 %32
    • Using the blue plastic opening tool, pull the rubber covers off the screen screws.
    Pergunte ao FixBot
    Comentar
  11. HP Compaq 6710b Screen Replacement: passo 11, imagem 1 %32
    • Using a T9 Torx screwdriver, remove the top four 5 mm screws.
    • Remove the bottom two 6 mm screws with the same screwdriver.
    Pergunte ao FixBot
    Comentar
  12. HP Compaq 6710b Screen Replacement: passo 12, imagem 1 %32 HP Compaq 6710b Screen Replacement: passo 12, imagem 2 %32 HP Compaq 6710b Screen Replacement: passo 12, imagem 3 %32
    • Using a flat head screwdriver, pry the plastic panel over the screen up starting at one of the hinges.
    • Using the flathead, continue running the it under the the plastic screen edge and gently pry it off.
    • If you press the screwdriver tip down (by lifting the handle), the screen panel pops off easier.
    Pergunte ao FixBot
    Comentar
  13. HP Compaq 6710b Screen Replacement: passo 13, imagem 1 %32 HP Compaq 6710b Screen Replacement: passo 13, imagem 2 %32 HP Compaq 6710b Screen Replacement: passo 13, imagem 3 %32
    • Slowly pry back the of the screen.
    • It is easiest to work both sides free at the same time.
    Pergunte ao FixBot
    Comentar
  14. HP Compaq 6710b Screen Replacement: passo 14, imagem 1 %32
    • Using your fingers, take out the two connections near the hinges.
    Pergunte ao FixBot
    Comentar
  15. HP Compaq 6710b Screen Replacement: passo 15, imagem 1 %32
    • Using the T9 Torx screwdriver, unscrew the four 4mm screws.
    Pergunte ao FixBot
    Comentar
  16. HP Compaq 6710b Screen Replacement: passo 16, imagem 1 %32 HP Compaq 6710b Screen Replacement: passo 16, imagem 2 %32
    • Tilt the screen up from the top to gain access to the screws on the side.
    • Go just far enough to get to the bottom screws to avoid damaging the bracket.
    • Using the PH00 screwdriver, unscrew the 2.5mm screws on the side of the screen. There should be 4 on each side.
    • You can now take out the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Khulan Orgil
Membro desde: 04/14/15
1.186 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 4-2, Maness Spring 2015 Membro de Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Membros
Autoria de 6 guias
1Comentário do guia
thank you I found it very interesting
Hassan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 41
Ao todo: 6,221
