Ir para o conteúdo principal
HP Compaq 6710b Keyboard Replacement
O que você precisa
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Compaq 6710b Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 HP Compaq 6710b Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
    Pergunte ao FixBot
    Comentar
  2. HP Compaq 6710b Keyboard Replacement: passo 2, imagem 1 %32
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
    Pergunte ao FixBot
    Comentar
  3. HP Compaq 6710b Keyboard Replacement: passo 3, imagem 1 %32 HP Compaq 6710b Keyboard Replacement: passo 3, imagem 2 %32
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    Pergunte ao FixBot
    Comentar
  4. HP Compaq 6710b Keyboard Replacement: passo 4, imagem 1 %32
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Khulan Orgil
Membro desde: 04/14/15
1.186 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 4-2, Maness Spring 2015 Membro de Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Membros
Autoria de 6 guias
2Comentários do guia
No parts required to *replace* the keyboard?
David - Responder Compartilhar
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 5,723
