Ir para o conteúdo principal
HP Chromebook CB2L Motherboard Replacement
O que você precisa
  1. HP Chromebook CB2L Motherboard Replacement, Battery: passo 1, imagem 1 %32 HP Chromebook CB2L Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Motherboard Replacement: passo 2, imagem 1 %32 HP Chromebook CB2L Motherboard Replacement: passo 2, imagem 2 %32 HP Chromebook CB2L Motherboard Replacement: passo 2, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Motherboard Replacement: passo 3, imagem 1 %32
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Motherboard Replacement: passo 4, imagem 1 %32
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Motherboard Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Motherboard Replacement, Speaker: passo 6, imagem 1 %32
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Motherboard Replacement: passo 7, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Motherboard Replacement: passo 8, imagem 1 %32 HP Chromebook CB2L Motherboard Replacement: passo 8, imagem 2 %32 HP Chromebook CB2L Motherboard Replacement: passo 8, imagem 3 %32
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Motherboard Replacement: passo 9, imagem 1 %32
    • Use the plastic opening tool to remove the speaker from back panel.
  10. HP Chromebook CB2L Motherboard Replacement, Motherboard: passo 10, imagem 1 %32 HP Chromebook CB2L Motherboard Replacement, Motherboard: passo 10, imagem 2 %32 HP Chromebook CB2L Motherboard Replacement, Motherboard: passo 10, imagem 3 %32
    • Disconnect the black wire which connects the audio port to the motherboard.
    • Use the plastic opening tool to lift the white tab.
    • Use the plastic opening tool to disconnect the gold strip which connects the audio port to the motherboard.
  11. HP Chromebook CB2L Motherboard Replacement: passo 11, imagem 1 %32 HP Chromebook CB2L Motherboard Replacement: passo 11, imagem 2 %32
    • Lift the black tab using the plastic opening tool.
    • Remove the two white strips from the motherboard.
  12. HP Chromebook CB2L Motherboard Replacement: passo 12, imagem 1 %32 HP Chromebook CB2L Motherboard Replacement: passo 12, imagem 2 %32
    • Lift the black and silver connector using plastic opening tool as shown.
    • Remove the white and black wires by rotating them counterclockwise and gently lifting them.
  13. HP Chromebook CB2L Motherboard Replacement: passo 13, imagem 1 %32 HP Chromebook CB2L Motherboard Replacement: passo 13, imagem 2 %32 HP Chromebook CB2L Motherboard Replacement: passo 13, imagem 3 %32
    • Remove the three 1.2mm screws using the Phillips #1 screwdriver.
  14. HP Chromebook CB2L Motherboard Replacement: passo 14, imagem 1 %32
    • Using the plastic opening tool lift the motherboard out of the back panel.
Conclusão
Gregory Hinkson
Membro desde: 02/13/17
352 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G6, Lacy Spring 2017 Membro de USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 649
