Ir para o conteúdo principal
HP Chromebook 14-q029wm Motherboard Replacement
O que você precisa
  1. HP Chromebook 14-q029wm Motherboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove nine 5mm Phillips #0 screws from the back case.
    • Remove the rubber caps using a spudger.
    • Remove the four remaining 5mm Phillips #0 screws.
  2. HP Chromebook 14-q029wm Motherboard Replacement: passo 2, imagem 1 %32
    • Use an opening tool to unclip the bottom plastic covering of the laptop.
    • Go around the sides of the laptop until the bottom unclips completely and comes off of the laptop.
    • Be careful not to break the plastic clips.
  3. HP Chromebook 14-q029wm Motherboard Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Once the bottom is completely unclipped, remove the covering slowly so you do not pull and rip the wires.
    • There is a little black lever that you have to pull in order to remove the wires. They are found on top of where the wires are connected.
    • Remove the larger wire first.
    • Then remove the smaller wire.
    • It is better to use a pair of tweezers for accuracy
    • From there the keyboard should completely come off.
  4. HP Chromebook 14-q029wm Motherboard Replacement, Battery: passo 4, imagem 1 %32
    • Use your fingers to pull the white tab out of the black slot above the battery.
  5. HP Chromebook 14-q029wm Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the 3mm Phillips #0 screws.
  6. HP Chromebook 14-q029wm Motherboard Replacement: passo 6, imagem 1 %32
    • Pick up and gently remove the battery.
  7. HP Chromebook 14-q029wm Motherboard Replacement, Fan: passo 7, imagem 1 %32 HP Chromebook 14-q029wm Motherboard Replacement, Fan: passo 7, imagem 2 %32
    • Remove the three 3mm Phillips #0 screws.
    • The bottom right screw may be covered by the fan's wires.
  8. HP Chromebook 14-q029wm Motherboard Replacement: passo 8, imagem 1 %32
    • Using your fingers or an opening tool, remove the cable connecting the fan to the motherboard.
    • Gently remove the fan.
  9. HP Chromebook 14-q029wm Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Remove the five 2mm Phillips #0 screws from the motherboard.
  10. HP Chromebook 14-q029wm Motherboard Replacement: passo 10, imagem 1 %32
    • Unclip the black lever holding the connector in place to the motherboard and remove the connector.
  11. HP Chromebook 14-q029wm Motherboard Replacement: passo 11, imagem 1 %32 HP Chromebook 14-q029wm Motherboard Replacement: passo 11, imagem 2 %32
    • Unplug the wire connecting the speaker to the motherboard.
  12. HP Chromebook 14-q029wm Motherboard Replacement: passo 12, imagem 1 %32 HP Chromebook 14-q029wm Motherboard Replacement: passo 12, imagem 2 %32
    • Remove this connector found under the right side of the motherboard.
  13. HP Chromebook 14-q029wm Motherboard Replacement: passo 13, imagem 1 %32 HP Chromebook 14-q029wm Motherboard Replacement: passo 13, imagem 2 %32
    • Lift the right side of the motherboard slightly and slide the USB and other ports out from the left side.
    • The motherboard should be able to turn on its side after that.
  14. HP Chromebook 14-q029wm Motherboard Replacement: passo 14, imagem 1 %32 HP Chromebook 14-q029wm Motherboard Replacement: passo 14, imagem 2 %32
    • Remove the four 2mm Phillips #0 screws from the heat sink.
    • Remove the heat sink from the motherboard.
  15. HP Chromebook 14-q029wm Motherboard Replacement: passo 15, imagem 1 %32 HP Chromebook 14-q029wm Motherboard Replacement: passo 15, imagem 2 %32
    • Looking at the right side of the motherboard, remove the Wi-Fi card that is connected to the motherboard.
  16. HP Chromebook 14-q029wm Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the black wire from the screen.
    • Remove the motherboard from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Pratt
Membro desde: 11/05/19
669 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S1-G5, Barthe Fall 2019 Membro de UMass Dartmouth, Team S1-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 345
