Introdução
This guide will walk you through the replacement of a RAM that doesn’t hold enough storage in your HP Chromebook 14-ak041dx. The RAM is located inside the motherboard, so to replace the RAM, you will need to desolder it from the motherboard..
O que você precisa
Ferramenta utilizada nesse passo:Tweezers$4.99
Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
Remove the heat sink from the laptop.
Remove the single 2.5mm Phillips #00 screw from the wireless card.
Gently pull the wireless card from the motherboard to remove it.
Gently pull the wire connector with a pair of tweezers to free it from the motherboard.
Use a pair of tweezers to remove the black ribbon cable from its connector.
Use the tweezers to detach the wire connector from the bottom left corner of the motherboard.
Carefully desolder the RAM using a soldering iron.
For soldering help, visit iFixit's How to Solder and Desolder Connections guide.
Uma outra pessoa concluiu este guia.
