Ir para o conteúdo principal
HP Chromebook 14-Q010DX USB/SD card Replacement
O que você precisa
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: passo 1, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: passo 1, imagem 2 %32
      • Flip the laptop so the base of the laptop is facing you.
      • Using the #00 screwdriver, unscrew the 13 screws.
      Pergunte ao FixBot
      Comentar
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 2, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement: passo 2, imagem 2 %32 HP Chromebook 14-Q010DX USB/SD card Replacement: passo 2, imagem 3 %32
      • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
      • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
      Pergunte ao FixBot
      Comentar
    3. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 3, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement: passo 3, imagem 2 %32 HP Chromebook 14-Q010DX USB/SD card Replacement: passo 3, imagem 3 %32
      • Warning! Handle the flaps and ribbon cables with care to prevent damage.
      • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
      • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
      • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
      Pergunte ao FixBot
      Comentar
    4. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 4, imagem 1 %32
      • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
      • The tape has no function other than to keep the wire tucked away.
      Pergunte ao FixBot
      Comentar
    5. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 5, imagem 1 %32
      • Set aside the detached keyboard.
      Pergunte ao FixBot
      Comentar
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: passo 6, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: passo 6, imagem 2 %32 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: passo 6, imagem 3 %32
      • Undo the black tape located on the bottom from the frame of the laptop.
      • Using fingers or the spudger, slide out the black connector indicated on the left.
      • Use a #00 screwdriver to remove the two screws.
      Pergunte ao FixBot
      Comentar
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 7, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement: passo 7, imagem 2 %32
      • Gently remove the speakers.
      Pergunte ao FixBot
      Comentar
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: passo 8, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: passo 8, imagem 2 %32
      • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
      • Lift the black flaps and gently pull the strip out.
      • Set the strip aside.
      Pergunte ao FixBot
      Comentar
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 9, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement: passo 9, imagem 2 %32 HP Chromebook 14-Q010DX USB/SD card Replacement: passo 9, imagem 3 %32
      • Remove the screw.
      • Use your fingers to pull the white tab out of the black slot above the battery.
      Pergunte ao FixBot
      Comentar
    3. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 10, imagem 1 %32
      • Gently remove battery.
      Pergunte ao FixBot
      Comentar
    1. HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: passo 11, imagem 1 %32 HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: passo 11, imagem 2 %32
      • Remove screw indicated by the red circle at the top of the card port.
      Pergunte ao FixBot
      Comentar
    2. HP Chromebook 14-Q010DX USB/SD card Replacement: passo 12, imagem 1 %32
      • Gently remove the USB/SD card port.
      Pergunte ao FixBot
      Comentar
Conclusão
Kevin Piper
Membro desde: 01/16/15
1.602 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 17-2, Watkins Winter 2015 Membro de USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Membros
Autoria de 56 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 792
