Ir para o conteúdo principal
HP Chromebook 14-Q010DX Speaker Replacement
O que você precisa
  1. HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: passo 1, imagem 1 %32 HP Chromebook 14-Q010DX Speaker Replacement, Keyboard and Touchpad: passo 1, imagem 2 %32
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Pergunte ao FixBot
    Comentar
  2. HP Chromebook 14-Q010DX Speaker Replacement: passo 2, imagem 1 %32 HP Chromebook 14-Q010DX Speaker Replacement: passo 2, imagem 2 %32 HP Chromebook 14-Q010DX Speaker Replacement: passo 2, imagem 3 %32
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Pergunte ao FixBot
    Comentar
  3. HP Chromebook 14-Q010DX Speaker Replacement: passo 3, imagem 1 %32 HP Chromebook 14-Q010DX Speaker Replacement: passo 3, imagem 2 %32 HP Chromebook 14-Q010DX Speaker Replacement: passo 3, imagem 3 %32
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Pergunte ao FixBot
    Comentar
  4. HP Chromebook 14-Q010DX Speaker Replacement: passo 4, imagem 1 %32
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Pergunte ao FixBot
    Comentar
  5. HP Chromebook 14-Q010DX Speaker Replacement: passo 5, imagem 1 %32
    • Set aside the detached keyboard.
    Pergunte ao FixBot
    Comentar
  6. HP Chromebook 14-Q010DX Speaker Replacement, Speaker: passo 6, imagem 1 %32 HP Chromebook 14-Q010DX Speaker Replacement, Speaker: passo 6, imagem 2 %32 HP Chromebook 14-Q010DX Speaker Replacement, Speaker: passo 6, imagem 3 %32
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    Pergunte ao FixBot
    Comentar
  7. HP Chromebook 14-Q010DX Speaker Replacement: passo 7, imagem 1 %32 HP Chromebook 14-Q010DX Speaker Replacement: passo 7, imagem 2 %32
    • Gently remove the speakers.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Brandon Nolen
Membro desde: 01/28/15
3.536 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 17-2, Watkins Winter 2015 Membro de USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 37
Ao todo: 1,460
