Introdução
This guide will require removal of 1x3mm screws.
O que você precisa
Flip the laptop so the base of the laptop is facing you.
Using the #00 screwdriver, unscrew the 13 screws.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
Using a spudger, remove the white and black cables from the card.
Remove the 3 screws around the fan.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
14 outras pessoas executaram este guia.
5Comentários do guia
Thanks so much for your clearly , detailed and easy to follow guide, nice job!
Buenas tarde y despuesnde quitar el disco duro que se hace se cambia por otro igual o que modelo
Can you add more storage on the HP Chromebook 14 SMB about 500GB. I also want to know if the Chromebook can run Windows 10 without any problems.
Useful. Wish I would have read it B4 I started this project.
how do i upgrde my chrom browser?
