Introdução
This guide requires removal of 3x3mm screws from the fan assembly.
O que você precisa
Flip the laptop so the base of the laptop is facing you.
Using the #00 screwdriver, unscrew the 13 screws.
Remove the 3 screws around the fan.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
5 outras pessoas executaram este guia.
